Carl 61 Fleetwood Phyllis
0 Members and 4 Guests are viewing this topic.
Clewisiii
I would like to plate one of these fuel door brackets. But it is to big for my tank. I may just paint this.
Cadman-iac
  So what is the biggest thing that you can/have plate(d) with your system?
CLC# 32373
Clewisiii
Quote from: Cadman-iac on September 15, 2024, 01:06:24 AMSo what is the biggest thing that you can/have plate(d) with your system?
I did the parking lamps. Bracket in yellow lamp in clear.
There is a way to do longer pieces with the same amount of electrolyte. Use a 4 or 6 inch drain pipe with a cap on one end. You can transfer your electrolyte into it to do longer skinny pieces.
Clewisiii
Laundry and lawn mowing day today, so I did not clean up much. But I get a little done.
The big thing is those fuel door reinforcement rods. Very rusty crusty and took a while to clean before plating.
I am taking a 4 day weekend next weekend. So I will try to start cleaning up that firewall.
Cadman-iac
  When you say electrolyte, what exactly do you use for this? Is it water that you add a chemical to, or is it an acid like what you clean up the parts in?
 Nice job on those lights too. You are probably saving a ton of money doing this yourself too.
 Rick
CLC# 32373
Clewisiii
Quote from: Cadman-iac on September 16, 2024, 08:42:38 PMWhen you say electrolyte, what exactly do you use for this? Is it water that you add a chemical to, or is it an acid like what you clean up the parts in?
 Rick
I used starter chemicals from Caswell plating. But it is acids and salts. Some people start making their own with vinegar. I maintain mine with Hydrochloric acid. I have noticed my chemical has gotten better over time. I don't know if that is due to more zinc being suspended in solution. Years ago I did have a batch somehow become contaminated. Everything I tried to plate came out black.
Clewisiii
DA$% &T
This morning before leaving for work I went into my basement to photograph a part for someone in Germany.
I noticed that the lid of one of my storage boxes was holding soapy water. I can only assume that my dishwasher or sink above was leaking. I moved stuff out of the way and decided to investigate after work.
Well turns out on the shelf to the left I had my restored rear parcel shelf cover. It is long so I had two bags on it with the split in the middle. The leak was over this bag. So it protected all the stuff below it. But half the water ended up in the bag, and the other half traveled to the right and landed on the storage box lid.
So now I need to remake this parcel shelf. Dang. And it had turned out so nicely.
Cadillac Jack 82
Quote from: Clewisiii on September 17, 2024, 04:21:49 PMDA$% &T
Looks like it could be saved OR sell it to another 61 owner who needs one too.
CLC Member #30850
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
Clewisiii
The fasteners are almost done. Maybe through the weekend.
The next big thing will be restoring and plating the tail lights like I did the parking lamps.
Clewisiii
So I am using prebent brake lines for 1962 on my 61. So far I have only needed to modify one area on the line going back to the rear.
I have just finished restoring a divider block for the front lines. When it comes time I will need to drill the frame to secure. But I will only do that after I connect to the master Cylinder
I will need to get the master and booster cleaned and rebuilt. I bought one from 62 supposedly rebuilt. But looking at the cosmetic condition of it I do not trust their work. I have tried opening the booster. But I think they painted it closed.
Clewisiii
So little hardware left to restore. I should be starting on the tail lights over the weekend.
Clewisiii
First one done. I need to verify how much and what color wires I have left.
I had a 3 gallon bucket of acetone I used to clean these bigger parts. Well it all evaporated while in a "sealed" bucket inside my chemical cabinet.
Clewisiii
The plastic bulb base for one of these was broken.
Luckily I had saved an extra one from the front parking lights. I have more on my parts car. But it would be a lot of disassembly to dig one out.
Clewisiii
I am almost out of the bulb base terminal ends. This completes everything exterior. But I may need more for interior ends.
Clewisiii
I cannot believe it but I misplaced one of them. I don't know if I was carrying it around as I looked for the plug base. I may have randomly set it down.
Clewisiii
Found it. I carried it into the basement with me to get wire.
Clewisiii
Testing the lights. One more to do tomorrow.
One bulb has two filaments. The other is just one.
I like the different illumination with the cleaned housing over the dirty one.
Maybe Members should be looking at their own lights when complaining about dull lights.
David King (kz78hy)
Dual wire version will be fog lamp and single wire will be non-fog lamp.
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
Clewisiii
#1319
I picked up my bumper brackets from the powder coater today. So with brackets done, chrome done, and hardware refinished, I want to reassemble the bumpers. But that will be stupid. I am not putting them back on the car till after paint.
I had a spare air cleaner powder coated. I have a decal for it, but I will need a lid gasket. There are pits showing through on the lid. But I wanted to see one powder coated. It is heavier then the painted one.
Here is the one I painted. I did some filler on this. So even with pits it is not as noticeable.
