Carl 61 Fleetwood Phyllis
Clewisiii
I have some issues. My presser foot arm is not lifting. But this removes the edge bulk from leather very nicely. For french seams I want about a 1/2 inch edge. But this thing can apparently due up to 2 inch. Which should help with piping.
Looks like you are going to need a bigger house.
Clewisiii
Tuning up well. Still needs some tension and a little timing adjustment.
It is better now but I had some real issues with the left hand bobbin hook holding to much material. And the right hand hook skipping stitches.
I had to remove the post cover plates as they were hanging up the feed dog and plate.
I have mostly figured out the leather skiver. But it is hard to clean and is jambing up with all the different test samples I have worked with so far.
Clewisiii
More trinkets to drop in the glovebox some day.
Clewisiii
I got a 4 ounce test sample of paint today. They shipped it in a big box in a bigger box. Maybe that was for insulation to the cold.
I tested a little from a brush. But I will leave the heat on in my shop over night and spray a test sample tomorrow.
Clewisiii
Ok. I like the color. It is a little more bright then the original. But I like that.
The paint and clear coat laid down nice and smooth on the testers.
I sprayed what was left on the firewall. If i had ordered 3 of these I could have done two coats and be good for the firewall.
The firewall shows more orange peel and texture. But it is very textured and has many coats of primer that I am not going to block sand. With how much all of this gets covered up I do not care. It is the body I will work to sand smooth.
Clewisiii
I picked this up off of Ebay calling itself a hatpin.
Whatever it was made for, I think I am going to make a leather driving logbook and mount this to the cover.
kudims
Is it satin (matte) paint and clearcoat? Or is it just gloss paint - all in one?
Clewisiii
Quote from: kudims on January 04, 2025, 03:39:07 PMIs it satin (matte) paint and clearcoat? Or is it just gloss paint - all in one?
I am doing basecoat clearcoat. Not single stage. It will be easier for me to work with doing it myself.
Clewisiii
My paint supplies are ordered.
Clewisiii
My paint, clear coat, primer/sealer, and various hardeners and reducers arrived today. I most likly will not get to it until fall at the earliest. But I am happy to have the supplies.
Clewisiii
I started painting in some of my chrome.
The ash trays did not plate on the insides so I painted them with a chrome paint.
The air vent black background was painted.
But I am having trouble with the dash lettering background. The paint is not filling in corners or edges. So I will strip this paint back off and sand the chrome for better adhesion. A wood popsicle stick does work well for cleaning off the tops of the letters.
Clewisiii
Just for fun. Front and rear bumper chrome photo with cut out background.
The smiley face was completly unintentional.
Clewisiii
Looks like my oil leak is at the back of the oil pan or the rear seal.
Some oil on the pan and some coming out of the inspection cover.
kudims
Quote from: Clewisiii on January 30, 2025, 08:02:18 PMLooks like my oil leak is at the back of the oil pan or the rear seal.
More likely it comes through the rear crankshaft cap, where there is a hole for high pressure oil line from the pump. See on the photo what I did with red thread sealant, and it completely resolved the problem
Clewisiii
I decided that I only need to replace the front door hinge pins.
So I ordered a set. I will rebuild these before I start the main bodywork this summer. 20250131_201534.jpg
Clewisiii
So what is my next order of operations. The goal in spring is to put my body back on ghe frame.
Before that I would like to.
Finsh installing all brakes
Install new hydraulic shocks
Buy fuel tank.
Figure out how fuel lines transition from metal to rubber under the hood. And the proper routing.
Finish painting firewall.
That really is not much. About $1300 in supplies still needed for that.
I just need to set aside the time.
James Landi
Carl,
Please provide us with your expertise regarding your choice of shocks... gas verses hydraulics as well as your choice of manufacturers.  While there's a good deal of discussion on the forum with regard to tires, there's not much about shocks. Thanks,   James
Clewisiii
Quote from: James Landi on February 03, 2025, 07:12:46 AMCarl,
I already had purchased a set of Gabriel Classics. But they are gas charged. I started hunting down to buy NOS delco shocks. But I dont think I want to use 60 year old shocks. The only place I know of that sells hydraulic shocks for my car is Shocks2Springs.
Clewisiii
